Old 05-28-2008, 03:33 PM
Default Santa Anita Surface
The story keeps changing. Here was the news as of 4 days ago:
http://www.drf.com/news/article/94859.html
The news today has totally changed:
http://news.bloodhorse.com/article/45447.htm
Old 05-28-2008, 03:41 PM
>>>“I’m recommending removing the surface and putting in a brand new base,” he said. “The options (for replacement) would be a porous asphalt base or a specialized grid layer.”<<<
If they did that at every track thinking about going to poly, there'd be no need for poly....
Old 05-28-2008, 03:48 PM
hi_im_god's Avatar
i don't think the story totally changed.
what i read is they intend to keep the current surface but have decided to replace the asphalt layer below that wasn't draining properly.
it'll be the same surface with a different base.
what i wonder about is if the problem with drainage was the asphalt, how did the pro-ride compound they added resolve anything?
Old 05-28-2008, 03:51 PM
Honu's Avatar
Honu Honu is offline
I dont know for sure but I would guess that the drain has been clogged by the material that Cushion track had put down , a very fine sand that has prevented the system for working properly.
Horses are like strawberries....they can go bad overnight. Charlie Whittingham
Old 05-28-2008, 06:28 PM
10 pnt move up's Avatar
this is exactly why I don't like using porous asphalt, its difficult to install and if not done right, or a few glitches here are there it does not drain.
