Old 02-13-2007, 06:37 PM
randallscott35's Avatar
Idlewild Airport
Default Is This True?
Got this forward.
In the 16th and 17th centuries, everything had to be
transported by ship and it was also before commercial fertilizer's
invention, so large shipments of manure were common.
It was shipped dry, because in dry form it weighed a lot less than when
wet, but once water (at sea) hit it, it not only became heavier, but the
process of fermentation began again, of which a by product is methane
gas. As the stuff was stored below decks in bundles you can see what
could (and did) happen.
Methane began to build up below decks and the first time someone came
below at night with a lantern, BOOOOM!
Several ships were destroyed in this manner before it was determined
just what was happening
After that, the bundles of manure were always stamped with the term
"Ship High In Transport" on them, which meant for the sailors to stow it
high enough off the lower decks so that any water that came into the
hold would not touch this volatile cargo and start the production of
methane.
Thus evolved the term "S.H.I.T " , (Ship High In Transport) which has
come down through the centuries and is in use to this very day.
You probably did not know the true history of this word.
Neither did I.
I had always thought it was a golf term.
