Old 08-21-2018, 03:53 PM
fantini33's Avatar
fantini33 fantini33 is offline
Default Grand Slam Bet
I have found the Grand Slam bet at the NYRA tracks to be a hidden gem and a healthy alternative to addictively playing Pick 4's and some pick 5's.With this being an off day I thought it would be an excellent time to drop this note and throw out my ideas.
For those they may be unaware of exactly what the Grand Slam bet is I will briefly explain. It is a multi race wager that ends with the feature every day, typically the race before the nightcap. It begins 3 races prior to create a 4 race sequence. In the 1st three legs your horse only need to hit the board, while in the feature you must select the winner. You can play it like any sequence, singling or using a few runners if you want, with the cost calculated out the same way you would play a pick 3, 4, 5 etc. You can have multiple horses within a single race move through the 1st 3 legs if you are so fortunate.
Good Luck......and may a Derby Trailer lead the way to the window!
Ed
