Old 04-01-2017, 11:46 AM
hondo's Avatar
hondo hondo is offline
Louisiana Downs
Default Donating to Old Friends using Amazon Smile
Some of you may already be aware and are using this and if so great, I have been using since the beginning of the year and it make sense as it does not cost you anything and you can do a little good when use make an Amazon purchase since Amazon donates 0.5% of your eligible purchases.
Every item available for purchase on www.amazon.com is also available on AmazonSmile (www.smile.amazon.com) at the same price. You will see eligible products marked "Eligible for AmazonSmile donation" on their product detail pages.
It is VERY easy to do. First, go to smile.amazon.com. Login with your normal amazon account credentials. Scroll down to where you can pick your own charitable organization. Type in Old Friends, Inc and select it when it shows up. That's it...can shop as usual.
Don"t forget to create a bookmark to AmazonSmile and you will always start there.
Old 04-01-2017, 12:36 PM
casp0555 casp0555 is offline
I have not used it will from now on. Thanks for the heads up Hondo!
