Old 10-24-2006, 10:49 AM
dellinger63's Avatar
Default Cornell Collars
I was called and asked about this 'equipment change' last night and understand several will be using it wed. at Keenland.
After doing some investigation, I now know it prevents dislacement of the soft pallet and has been used in Australia but my question is will it replace tounge ties and more importantly should it be considered a possitive or negative when 'cappin horses who are making the change?
Old 10-24-2006, 10:54 AM
The Bid's Avatar
The Bid The Bid is offline
Its very important you realize whos using one. Yes a tounge tie is still used. They are good devices to cheat and catch a price with. Makes a ton of difference. It does the same thing a Tie back does, except you can remove it after they run. Youll notice the Cornell by looking at the top of the horses nose. You can detect the Cornell by fuzzy material where the drop usually is.
Old 10-24-2006, 11:03 AM
thanks my understanding is that they are declaring it as an equipment change (similar to blinks on/off) at least at Keenland.
