Old 02-27-2013, 01:57 PM
dino dino is offline
Turf Paradise
Default Pick 3
just curious if anyone knows the gulfstream pick 3 rules. the 3rd was on the turf and now it's off the turf. what happens with pick 3 starting in race 2.
Old 02-27-2013, 09:57 PM
ateamstupid's Avatar
Super Mod.. and Super Fly
As long as the race is taken off the turf before the sequence starts, nothing changes, nor should it.
Old 02-28-2013, 06:42 AM
Turf Paradise
"nor should it"? I bet the 2nd - 4th 5 minutes before the 1st and then they take the 3rd off the turf after I leave OTB and somehow I should get screwed because of the late change. At worst it should be a refund. Total BS
Old 02-28-2013, 07:26 AM
Maybe they should check YOUR schedule next time. For someone that rages so much against entitlement you sure feel entitled in this instance.
Old 02-28-2013, 09:08 AM
Ever heard of online wagering? Gulfstream owes you nothing in this scenario. They took the race off the turf 35 minutes before the sequence started and you want a refund because you left the OTB earlier than that? Do you realize how ridiculous that sounds?
Old 02-28-2013, 10:40 AM
try to make a point and once again get insulted by the same people. time for you guys to go upstairs because your mommy is calling you.
Your point has no validity to it. They took the races off the turf before the sequance started. It's unfortunate, but it's nothing more than a case of bad luck. Now if they took it off after the 2nd, you would be absolutely correct to gripe.
Old 02-28-2013, 11:13 AM
hi_im_god's Avatar
how long would the line for refunds be once everyone knows you can make a potentially risk free bet whenever it's rained? win and you cash. lose and you get a refund.
sorry this happened but i see no fix other than what others have already said. if you bet 35 minutes before post and have no cancel option, you've taken the risk. blaming the track is just bad form.
Old 02-28-2013, 11:17 AM
Turf Paradise
Thank you for the last 2 civil responses. I can see your points.
Old 03-01-2013, 07:59 AM
Knock this off guys..
