Old 12-28-2009, 12:00 PM
docicu3 docicu3 is offline
Default Janikowski 61 yard field goal......rule question?
Link for replay below...
http://nfl.fanhouse.com/team/cleveland-browns
Given that the only time a field goal is made from this distance it is a line drive with low flying trajectory, is it within the rules of the game to put a defender at the cross bar to deflect the ball as it passes.
It seems that this ball cleared by no more than 6-12 inches which for these guys is the equivalent of grabbing the rim of a basket since they are both 10 feet high.
I know you cannot use another players back to hurl yourself over the line of scrimmage but can you block a ball at the point it clears a cross bar and upright.
Old 12-28-2009, 12:08 PM
ddthetide's Avatar
as far as i know Yes it can be blocked. the same as, if it were short it could be fielded and returned.
Coach Paul Bryant
Old 12-28-2009, 12:10 PM
timmgirvan's Avatar
timmgirvan timmgirvan is offline
That would be a trick,wouldn't it!
Old 12-28-2009, 12:15 PM
ddthetide's Avatar
i saw it tried once, a LONG time ago, on a long FG try. i don't remember who it was. i think a tall receiver with a good vertical.
i've also seen a short attempt returned for a TD. caught the defenders "napping"
Coach Paul Bryant
Another great moment in Giants history.
http://www.youtube.com/watch?v=7wuQ9kd_m2A
Old 12-28-2009, 12:17 PM
Can you grab the crossbar and use it to get a better jump which is really what I was asking initially but didn't state the question accurately. So Mangenius actually missed a chance to look smart here as he should have had a defensive back or someone with vertical back at the goal line even if it was the last play of the half
Old 12-28-2009, 12:18 PM
ddthetide's Avatar
i didn't remember that. i was thinking, i'd seen it in a college game.
Coach Paul Bryant
Old 12-28-2009, 12:19 PM
ddthetide's Avatar
can not grab the crossbar. would be the same a the "pyramid" rule.
anything to keep 3pts off the board. think of the lift that would have been going in to the locker-room.
Coach Paul Bryant
Old 12-28-2009, 12:25 PM
Crown@club's Avatar
You either try hard for the push to block it, since its most likely going to be a line drive, or Mangini should had Cribbs waiting back there just in case it was short.
Old 12-28-2009, 12:31 PM
I think you probably have a better chance of knocking a ball over that might be a tad short (going to hit the bar), then to actually knock down or block a ball going over.
Old 12-28-2009, 02:43 PM
notyep59 notyep59 is offline
Golden Gate
Didn't some team back in the 70's try to sign Andre the Giant just for this reason?? Think it was the Skins.
Old 12-28-2009, 03:11 PM
PeteMugg's Avatar
PeteMugg PeteMugg is offline
When will a hockey team sign one of these 900lbers to be a goalie. Just fill the damn thing up with pads and fat. Wouldn't even need the stick.
Old 12-28-2009, 03:52 PM
The missed field goal returns were a regular part of the game before they moved the goalposts from the front of the endzone to the back in 1974.
Teams posted a return man in the endzone nearly every FG attempt.
Old 12-28-2009, 04:00 PM
dagolfer33's Avatar
dagolfer33 dagolfer33 is offline
A field goal can only be blocked @ the line of scrimmage per NFL rules.
"Let the whiners and lazy cry about how impossible "they've" made it to win at this game." - Steve Byk
Old 12-28-2009, 09:51 PM
So you can't jump up and field the ball at the crossbar?
Old 12-28-2009, 10:02 PM
dagolfer33's Avatar
I was told by a very reliable source, that the crossbar and uprights are to be treated similar to the goal in basketball. No player can touch a ball that in the officials view could actually touch the upright or crossbar. Similar to goaltending rules.
Old 12-28-2009, 10:21 PM
Cannot find such a rule in the NFL rule book....
Old 12-28-2009, 10:26 PM
witchdoctor witchdoctor is offline
Tropical Park
I remember seeing that as a kid. In think it was the St Louis Cardnials that have someone back on a long FG attpt to try to block it at the crossbar. The player missed timed his jump and knocked the ball thru the uprights.
Old 12-28-2009, 10:42 PM
dagolfer33's Avatar
It is defined under the definition of the goaltending, Doc. Rule 12 section 3 article 1 sub (s) GOALTENDING
Old 12-28-2009, 11:45 PM
That's the rule they used for Prop's on the field as when Ochocinco slipped the ref a single dollar bill. In this case the player isn't using anything other than his body....no big deal I Just wanted to actually read the rule that dealt with blocked kicks
