Old 11-24-2009, 04:19 AM
docicu3 docicu3 is offline
Default Cost Of Printer Supplies....
The cost of the game has always been a popular discussion thread as it applies to take out. Another relatively expensive item for those that rely on printing your own PP's and premium speed figures or sheets is the insane cost of toner cartridges and paper. At about 80 dollars apiece for laser cartridges you get about 1000 of the advertised 2000 pages per cartridge.
Other than the pirate cartridges which often will destroy a printer I was wondering if anyone had found a cheaper way to limit this cost which doesn't seem to have a volume discount from the companies that make the cartridges?
Printing NY/Ky/So Cal cost about $250-$300 a month for paper and ink. Does anyone have any suggestions for limiting these costs or know of discount supplies that do not ruin your laser printer ??
Old 11-24-2009, 04:56 AM
Dave,
I expect that I use as much or more ink and paper as anyone. I have a HP LaserJet (CM1015 MFP) that takes the Q6000A (black) toner unit. They're about $75, $10 less when I buy 4-5 at a time. I get the full 2,400 or so pages from it though. Add $25 for paper.. so call it $100-$125/month. About the same as 20 newsprint versions of the Form.
One option is an ink-reducing mode on the printer... 'Draft' mode I think...
Old 11-24-2009, 05:13 AM
A key point here Steve.
Always print on the lowest quality mode to use the least amount of ink. It is faster too. I also recycle the paper. When I am done with a Form it goes into a pile and I use the backside to print another Form on it. So the same 30 sheets of paper are getting you two Forms.
Personally, I only print at home on the weekends, during the week, my employer is gracious enoungh to supply the paper and ink.....
Old 11-24-2009, 05:15 AM
I have an answer for you. I also have a laser printer, a Brother black and white printer. Cartridges are about $45 each, but, I buy the replacement ink powder in bulk which reduces that $45 to about $15.
The quailty is the same and, once I got the hang of it, it takes 5 minutes for the refilling.
These are not advertised or endorsed by the actual printer companies, but work fine.
Old 11-24-2009, 06:10 AM
johnny pinwheel johnny pinwheel is offline
my friend does the same thing. i just buy the form or post parade. the 4 to 6 bucks ends up costing less time and money. then again, i'm not that patient.
Old 11-24-2009, 06:25 AM
joeydb's Avatar
joeydb joeydb is offline
I have a color laser printer. I found that the cheapest place to buy toner is off of ebay. There are several people selling brand new toner cartridges and using ebay as a cheap store front.
The CMYK color lasers require four different toner cartridges: Cyan, Magenta, Yellow and Black. Black runs out the fastest.
I like the color laser because it allows me to print out my own metrics from computer-based analysis in color. At a glance when I go to the track, I can get a clear picture of the race very quickly.
SlewsMyHero's Avatar
SlewsMyHero SlewsMyHero is offline
I haven't printed out PPs in a long time, but when I did I would set my laser printer to print in "draft" mode, which uses much less toner. The print did not come out quite as dark, but it was certainly readable. Check to see if your printer has a draft or "toner saver" mode. Another thing I used to do is print to both sides of the paper. I would print my early cards, then flip the paper over, and print my late afternoon or evening cards on the reverse side. This is a big paper saver. There's no reason not to use both sides of the paper, especially when you're concerned about cost. You'll have to do some experimenting so that you know which way to put the paper in to print on the reverse side.
Old 11-24-2009, 06:33 AM
wow.....great suggestions from all of you and by the crack of clouds, I mean dawn.
I have an HP P1505 laser that I can see now has 5 separate ink settings as well as an "economode" setting that visibly uses even less ink than the lowest density setting. Who knew!!! None of these options are explained or noted in the HP manual.
Back to counting how many PP's and TGH figures you can get out of a 36A cartridge using "economode" and ink density 1.
Are there commercial kits for refilling the ink? That must really lower the cost? Frugal is fun....thank you all for the help.
Great to see you Jack.....
Old 11-24-2009, 09:31 AM
Dave,
understatement of the year.
Old 11-24-2009, 09:56 AM
VOL JACK's Avatar
VOL JACK VOL JACK is offline
Back in the day, I remember J.J. and Sam always talking about how many trees Steve used up in a weeks time.
jwkniska's Avatar
jwkniska jwkniska is offline
Depending on the printer, it'll either be draft mode or fast normal.
If you lower the print quality from normal to one of those, it should nearly double the number of pages you get.
Old 11-24-2009, 10:21 AM
Travis Stone's Avatar
Travis Stone Travis Stone is offline
While in college, I was responsible for the campus-wide print quota after running so many Brisnet buck-a-day PPs off the lab printers. True story.
Old 11-24-2009, 10:29 AM
You dont have to tell me! I used to go buy new ink for the office.. LOL
Old 11-24-2009, 10:30 AM
Old 11-24-2009, 11:03 AM
GBBob GBBob is offline
You ever end up betting the 5th at TB while handicapping the 3rd at GP?
hi im god quote
Old 11-24-2009, 11:12 AM
On opening day at Saratoga a few years ago I printed off the pps and one of the races got caught up in my bosses document. When he handed me my lost pps he handed me a $50 and asked me to put it on the 7.
Old 11-24-2009, 11:30 AM
I'll admit to some momentary confusion...."I can't believe they're dropping Quality Road into a 5k plater at Tampa, he must have really gone wrong."
Thankfully they put the track name and date at the top.
I don't ever do what SlewsMyHero does, because having two tracks from the same day on either side of the paper is a recipe for disaster for me. The backside of the recycled paper is always from previous days.
Old 11-24-2009, 12:08 PM
that is awesome
Old 11-24-2009, 08:48 PM
SCUDSBROTHER's Avatar
SCUDSBROTHER SCUDSBROTHER is offline
I don't know what you're looking for in printer features, but I can show you the way to significantly reduce the costs you're talking about. If you can find a printer that will use a Canon BCI-24 cartridge, then you're in bidness. Like it says, 5 cartridges for $7 (including shipping.)
http://shop.ebay.com/?_from=R40&_trk...8&_nkw=BCI-24+
I use a Canon i450. I haven't had trouble with the pirate cartridges. If I do, then I'm gunna buy another old printer that uses this cartridge. I used to use another printer, and pay that $20 a cartridge. F that. May not be that cheap to get these printers now. I haven't been paying attention. Getting one of those printers (maybe 10-15 different models will use the cartridge) is the only way I know to get around the expenses you're concerned about.
Old 11-24-2009, 09:13 PM
PatCummings PatCummings is offline
You guys ever thought about NOT printing them at all - I've really adapted to reading them off the screen and taking notes on separate paper.
