Old 02-06-2009, 09:42 AM
hoovesupsideyourhead's Avatar
Default otbs in baton rouge la?
im looking for a simocast spot..as ive got some time to kill sat..does anyone know where a spot is..thanks h
Old 02-06-2009, 09:46 AM
GBBob GBBob is offline
Can you get to the FG Sunday?
Old 02-06-2009, 12:22 PM
FGFan's Avatar
FGFan FGFan is offline
I think there is one in Port Allen, over the bridge heading west. They are called Aces and Races or Races and Aces in that area.
Old 02-06-2009, 01:33 PM
thanks..
Old 02-06-2009, 08:41 PM
deltagulf's Avatar
deltagulf deltagulf is offline
Hippodrome Bluebonnets
address is 722 lobdell hwy. south
port allen, la. 70767
there is one called aceses and races just off i-10 west. in port allen also on the service road should be exit 151 going west on 10 across the river from baton rouge. as you go on 10 west you can see it from the interstate.it will be on your right side. if you go past ext. 151 you went to far. get off of ext.151 and trun right. stay to your right then trn right at first street and follow it around to the aceses and races on service road next to i 10.
Old 02-06-2009, 08:45 PM
deltagulf's Avatar
there is one called aceses and races just off i-10 west. in port allen also on the service road should be exit 151 going west on 10 across the river from baton rouge. as you go on 10 west you can see it from the interstate.it will be on your right side. if you go past ext. 151 you went to far. get off of ext.151 and trun right. stay to your right then trn right at first street and follow it around to the aceses and races on service road next to i 10. this one is not the
one whos address is showing at beginning of post.
