Old 03-22-2008, 10:56 PM
joeydb's Avatar
joeydb joeydb is offline
Default Central list of track w/ surface type?
Hi guys,
My first post to DT Forums. I love what I've been reading, and I too am a huge fan of ATR with Steve Byk. I listen all the time.
I am a very casual handicapper and would like to make a computer program or spreadsheet to aid me with some supporting calculations, but first I would need to know exactly what surface is in use at what track. The PP's from racing form do not make this obvious enough for me.
For instance, if I know they're not on turf at Turfway, I would need to know about Turfway in order to not assume they are running on dirt. And vice-versa with Churchill.
Does anybody know of a complete and up-to-date list posted (and maintained) anywhere on the web? A pdf would work too if downloadable.
Thanks a ton...
Joe
Old 03-22-2008, 11:11 PM
No list I know of.
Polytrack
Turfway Park
Presque Isle Downs
Cushion Track
Hollywood Park
Golden Gate is Tapeta or something like that. I may be forgetting one or two but all the others are dirt.
Old 03-22-2008, 11:16 PM
ArlJim78 ArlJim78 is offline
Newmarket
I think Presque Isle is Tapeta.
Old 03-22-2008, 11:20 PM
Fair Grounds turf course consists of 30% Northern Lights 70% Crystal Meth.
Old 03-22-2008, 11:25 PM
jwkniska's Avatar
jwkniska jwkniska is offline
Originally Posted by SniperSB23
Polytrack
Turfway Park
Presque Isle - Tapeta - not polytrack
There are 2 types (mixes) of polytrack and they play totally different.
original mix: Keeneland, Arlington, Del Mar
special cold weather mix: Turfway, Woodbine
Old 03-22-2008, 11:26 PM
AeWingnut's Avatar
Joe,
welcome to the board
The form or other places should place a circled A for All-weather or a circled T for Turf. A circled X means they took the race off the turf.
I didn't find a directory for what surfaces are used but I did find the track directory for what abbreviations are used.
http://www.drf.com/entries/trackAbbreviations.html
Not all "All-Weather" surfaces are the same. California has foolishly mandated that all tracks shall be synthetic surfaces.
without talking about everywhere I will mention the poly race tracks
California
Del Mar is poly
Hollywood is Cusion track
Santa Anita is a mess
and Bay Meadows is probably going to close (still a dirt surface , oh they also race on the turf)
Arlington Park in Chicago - poly
Keeneland in Lexington, Ky- Poly
Turfway in Florence, Ky - poly
Presque Isle Downs in Erie, PA - Tapeta
Woodbine in Ontario, Canada - poly
ΜΟΛΩΝ ΛΑΒΕ
Old 03-22-2008, 11:29 PM
pick4's Avatar
pick4 pick4 is offline
Aqueduct
Originally Posted by joeydb
Hi guys,
Thanks a ton...
Joe
It's good that you are interested in racing but if you are serious it is very easy to figure out what surfaces each tracks have.
If you want to write code you should do homework on your own. You might learn a bit more about the game if you put the effort into downloading charts from equibase.com. You can sign up at drf.com and download past performances , or bookmark an informative site such as equidaily.com.
Old 03-22-2008, 11:36 PM
AeWingnut's Avatar
He may also want to use BrisNET
http://www.brisnet.com
it's all a matter of preference
ΜΟΛΩΝ ΛΑΒΕ
Old 03-23-2008, 12:23 PM
Originally Posted by AeWingnut
Joe,
California
Del Mar is poly
I think that is the big problem. There is no distinction on the Form for whether the race was taken off the turf onto a synthetic or off the turf onto the dirt. So in that case you really do need to know what surface that track has.
Old 03-23-2008, 08:13 PM
AeWingnut's Avatar
True, I also haven't accounted for the subtleties? of New York tracks like the inner dirt at Aqueduct or the different turf courses at Belmont
ΜΟΛΩΝ ΛΑΒΕ
Old 03-23-2008, 09:13 PM
hi_im_god's Avatar
are all dirt tracks the same?
I already know the answer but if you're slicing and dicing synthetics shouldn't you do the same for dirt?
