Old 01-10-2008, 02:35 PM
Default SA SURFACE: No decision today
Just off line with Rick Hammerle at Santa Anita..
No decision today. Likely tomorrow.
They are still analyzing dirt samples and getting construction estimates for how long it would take to take up the Cushion and lay down the dirt. (The timing of installation is a big issue right now and may end up being the deciding factor.)
Old 01-10-2008, 02:47 PM
geeker2's Avatar
geeker2 geeker2 is offline
Attachment 628
We've Gone Delirious
Old 01-10-2008, 05:06 PM
As of yesterday, it looked like a done deal that they were going to put in conventional dirt. But now they have figured out that it would not be as easy as they thought. They are having a hard time finding the right kind of dirt and they are realizing that the whole process would be much tougher than they originally thought. So now they're sort of back to square one. They're not sure what they're going to do. They've got some synthetic track expert who's coming from Australia to take a look at the track and he's going to give them his opinion as to whether they can add something to the surface to make it drain.
Old 01-10-2008, 05:13 PM
geeker2's Avatar
It's starting to sound more and more like a science project....where is Mr Peabody & Sherman when you need them.....
Old 01-10-2008, 05:18 PM
Maybe they would be better served if they all just gft.
Old 01-10-2008, 05:21 PM
How can adding something to the track help it drain? They have said that the sand is what is causing the blockage and from what I understand, sand is a large part of cushion track.
Are you considering anything major like going to FG or Oaklawn for their meets instead of staying out there?
Old 01-10-2008, 05:49 PM
Storm Cadet's Avatar
Storm Cadet Storm Cadet is offline
Default Here their solution!!!
Cushion track won't drain properly??? Use this....
The decisions you make today...dictate the life you'll lead tomorrow!
http://<b>http://www.facebook.com/pr...ef=profile</b>
Old 01-10-2008, 06:57 PM
What did SA do with their old dirt?
When Del Mar converted, they donated their dirt to a playground/soccer field complex, saved that group about a million bucks in construction costs.
Old 01-10-2008, 06:58 PM
letswastemoney's Avatar
letswastemoney letswastemoney is offline
They gave it away to the fans in small glass containers or something.
Old 01-10-2008, 07:04 PM
Unstable Unstable is offline
Ellis Park
I'm willing to give back my container of dirt if it helps.
Old 01-10-2008, 07:19 PM
TitanSooner TitanSooner is offline
they buried it under the infield parking lot and poured asphalt over it
Old 01-10-2008, 07:20 PM
Default bentonite
There is a substance called bentonite (http://en.wikipedia.org/wiki/Bentonite) that I have used on synthetic grass putting greens to help with drainage (it absorbs excess water). Whether or not it is safe for use on the synthetic tracks is another question.
Old 01-10-2008, 07:28 PM
You are a true racing fan!
Old 01-10-2008, 08:13 PM
From DRF:
In the meantime, Charles brought Ian Pearse, the founder of Pro-Ride, another synthetic surface company, in from Australia to consult on the ongoing problems at Santa Anita.
Pro-Ride was the finalist with Cushion Track. This tells me SA has little faith in the Cushion Track folks.
Old 01-10-2008, 08:19 PM
geeker2's Avatar
I think Cat Litter is cheaper.......
Old 01-10-2008, 09:01 PM
docicu3 docicu3 is offline
Does this mean the METAMUCIL idea Hammerle was describing Friday has been
"relieved of front runner status" in the quest for a solution of absorbing excess water that does not drain from subsequent rainfall??
Old 01-10-2008, 10:12 PM
pick4's Avatar
pick4 pick4 is offline
Aqueduct
Bob Ike posted on his blog :
I have been told that Santa Anita will begin removing Cushion Track on Monday or Tuesday, skip regularly scheduled cards on Thursday and Friday (Jan. 17-18), then run two or three days of “turf only” cards. All this while feverishly installing a conventional dirt track (which obviously will be approved by the CHRB at their Jan. 17 meeting) in order to get back on a normal racing schedule, presumably by Thursday, Jan. 24.
http://blog.bobikepicks.com/?p=411
Old 01-10-2008, 11:07 PM
Alan07 Alan07 is offline
The Sunshine Millions Classic is at Santa Anita and is to be shown on ESPN
Old 01-10-2008, 11:36 PM
That was what they were planning on doing. But now they have changed their minds because they realize that it's a much tougher job than they originally thought. They can't even find the proper dirt as of right now. So that is why they are pretty much back to square one and not sure what they are going to do.
Old 01-10-2008, 11:39 PM
No, I don't think so.
