Old 06-01-2006, 11:57 AM
oracle80
Default Belmont today/ my plays and info
race 1- #8 Brantley is a strong bet here. In her debut she was grabbed a hold of early after breaking a little slow. Made a move outside and ran evenly. Pletcher is 33% in 2nd starts and this filly is bred to run the longer distance much better today. Her sheet number that day was better than ANYTHING these have ever run. Add in the second start improvement and anything better than even money is a gift.
Race 2- We are going to go against the expected favorite #1 Audacious Chloe. In her debut she set moderate fractions and was still run down at the wire going 4 1/2 in rather average time. My clocker says #5 Velvet Charm is working like a very good race horse. Debuting with Lasix and gets the good outside post. Lets make it a Cold dd.
Race 4- Great reports on #3 Pletcher's One Tough Belle and #4 Zip of Fools. Use both in pik-3's and pik-4's and play an exacta box if there is any value there. Clocker says of the rest that only Donk's horse, #5, has shown anything at all, but far behind the other two.
Race 6- We don't like the favored #12 Bianca Diva and won't be including her in the top spot in exactas or pik-4's.
#3 Lady Jove worked like a real runner before her Saratoga debut last year where she flashed speed and was then laid off. Returned in May and middle moved into a very hot pace set by a runaway huge figure running winner. Drops in for a tag today and my clocker says has worked much improved since her last start. Trainer Alexander owns the horse so the drop is not a negative. Trainers like to drop down into winning spots but are often prevented from doing so by owners. Since he owns here he is taking an edge in placing her.
#4 LC Tornado ran a nice figure in her debut while racing wide and a bit green. Drops down for a tag in her 2nd start and adds blinkers. Flashed speed in her debut and with the blinkers could be cutting the pace. Use her on top.
use #'s 5 and 12 underneath in exactas.
Race 7- Hard race to play on its own merits so we will be spreading out in the pik-4. We will be using #'s 1,3,4,5,7,11 in this very hard turf sprint for Ny bred filles and mares.
race 8- very hard race as well. Problem here is that most of teh top contenders absolutely need the lead to win and all will be gunning. One could shake loose but they could also melt each othe as well. Noone has a figure edge either so we will be spreading out here as well looking for a price.
We will be using #'s 1,3,4,5,8,9
Race 9- which brings us to todays best bet and single in the Pik-4. #5 Mister Zee made his debut for Carlos Martin two starts back in a maiden claiming grass race. He caught a heaily favored MSW dropdown of Clements' named Hanging Curve and made a huge charging wide move while failing to change leads and ran a huge figure 2nd. Last year under Biancone's tutelage he caught very tough field in MSW's and a stakes race.
He ran back after the grass race in a rained off the turf race. Closed well enough for 4th. His main competitors #'s 2 and 4 were late scratches this morning and Mister Zee's sheet numbers layed over these in the first place. Carlos loves him today.
The pik-4 play is 3,4
1,3,4,5,7,11
1,3,4,5,8,9
5
72 dollars for each buck and I suggest you play it.
Good luck!!
