Old 07-29-2007, 11:59 AM
miles2135
Default Lawyer Ron's Time
I went back and watched the Go For Wand and The Whitney on NYRA.com and timed each race with a stop watch. I know this isnt very accurate but I was very close to the Go For Wand time and way off for the Whitney. I started the watch at the same time for each race. I got Lawyer Ron's time around 1:49 flat and Ginger Punches slightly slower (which is very close to the correct time). Thought this was interesting.
Old 07-29-2007, 12:14 PM
mes5107's Avatar
mes5107 mes5107 is offline
Golden Gate
I timed the Whitney 5 times and here were my results:
1:46.63
1:46.75
1:46.59
1:46.65
1:46.94
Obviously, there are several reasons for a margin of error, most of which the timing depends upon the replay being run at real speed.
Make sure you start your stopwatch when the first horse reaches the start/finish wire, not when they leave the gate.
I think that perhaps we should look at the Go For Wand featuring a regressed BSF by Ginger Punch in a winning effort as opposed to giving her an automatic 104.
Old 07-29-2007, 12:22 PM
smuthg's Avatar
smuthg smuthg is offline
interesting article on this subject on DRF... a few highlights...
"On the Beyer Speed Figure scale ... Lawyer Ron's raw figure in the Whitney was an astronomical 138, and applying a variant of -10 again would give him an implausible figure of 128, a level reached only by Ghostzapper in the last decade.
Awarding Lawyer Ron a 128 would mean giving runner-up Wanderin Boy, who had never exceeded a figure of 107 except at Keeneland (where he earned figures of 110 and 113 when that track was in its pre-Polytrack inside-speed heyday), a figure of nearly 120. Diamond Stripes, with consistent figures of 104-105-106-105 in his last four starts, would get about a 117." from DRF.
Old 07-29-2007, 12:47 PM
justindew's Avatar
justindew justindew is offline
I timed it twice using the replay on NTRA.com, and both times I started the clock less than a legth before the lead horses crossed the wire for the first time. My times:
1:47.00
1:47.00
If the replay is shown in real time, I think Lawyer Ron's time might be exactly right. Wow.
mes5107's Avatar
Golden Gate
My 5 clockings of the Go For Wand:
1:49.50
1:49.41
1:49.28
1:49.34
1:49.25
I believe the track was rather fast, but the Go For Wand was run rather slow. I agree that Lawyer Ron probably did not earn a 128, but a 120 is not out of the question. Perhaps we should use Diamond Stripes as a projection horse at about a 106. That would give Lawyer Ron a 115 which is 23 points off of the raw figure of 138. Applying that variant to Ginger Punch would leave her running a 91.
If we use an average of both projections for the variant (-10 and -23) we get an average variant of -17. That gives Lawyer Ron a 121 and Ginger Punch a 97.
I think the times were right.
Old 07-29-2007, 01:21 PM
JJP JJP is offline
Let's face it; the actual time really doesn't matter. We know the gaps involved separating the horses. Lets take a look at the top 5 finishers showing their top route dirt figs, and their last race Beyers:
Lawyer Ron 109, 108 (last race)
Wanderin Boy 113, 90 (last race). His two top dirt figs, 113 and 111, were loose on lead wire jobs at the old biased Kee. Is it likely he ran superior to those numbers? Its highly doubtful.
Diamond Stripes 106 & 104---he's been in the 104-106 range for his last 4 starts.
Fairbanks-115 & 103--the 115 was a loose on the lead runaway job. The 103, accomplished in his last, would be a far more likely number he'd run.
Dry Martini- 107 & 107--This is a horse who very often runs in the 100-103 area. The 107 was accomplished on Bute, at a track that often produces Beyers that are suspiciously high.
Likely projected figures before the race:
Dry Martini--102
Fairbanks--103
Diamond Stripes---106
These are the most likely numbers that could've occurred. In reality, the differential between Fairbanks and Dry Martini should be 2 pts, not 1. Based on this, Wanderin Boy would be 2 pts higher (1 length at 9f) than Diamond Stripes, giving him a 108. He's run a 107 and 106 on non-old Keeneland surfaces, so that is plausible. Higher than a 108 would not be likely. So for Lawyer Ron, we add on 8 pts, giving him a 116, a solid new top, but very likely considering his win margin. These are my projected figures (I use the Beyer scale):
Lawyer Ron 116
Wanderin Boy 108
Diamond Stripes 106
Fairbanks 103
Dry Martini 101
Old 07-29-2007, 01:48 PM
mes5107's Avatar
Golden Gate
Very sound reasoning in constructing your figure. The only problem is that leaves Ginger Punch with a 92 BSF. While it is possible that she scored a 6 length victory at a 92 figure, I think that it is unlikely. I believe she ran a slower than normal figure, but 12 points is quite a regression in a winning effort.
The question this poses is whether or not the timer was functioning properly in both races. Steven Crist (http://www.drf.com/news/article/87120.html) argues that the Whitney was an unlikely record time, but I think that it is more likely that the Go For Wand was an exceptionally slow race and both clockings are correct.
Old 07-29-2007, 01:55 PM
Travis Stone's Avatar
Travis Stone Travis Stone is offline
It is very possible (and likely) that Wanderin Boy ran a new top yesterday because he had everything go his own way on a track which favored his running style.
Old 07-29-2007, 04:13 PM
31lengths's Avatar
31lengths 31lengths is offline
Interesting....from the comments of the same article.
Steve Davidowitz says:
After Alan Klayman's report of the race clocking off the ABC Video Tape that he sdubmitted to this blog a few hours ago, I tried to time the race again off the NYRA website and the streaming video quality was poor. Would not trust my own previous clocking off that site. Strongly reitterate suggestion to NYRA to time this race with calibrated timing device off their in-house, real time, video replays). As others have suggested, the NYRA should do this as soon as possible.
Regards/Steve Davidowitz
Posted by: Steve Davidowitz | Jul 29, 2007 12:52:11 PM
"You miss 100% of the shots that you don't take."
Follow me with the Rays grounds crew at
https://twitter.com/TripleCrown59
www.facebook.com/TripleCrown59
K&S pics-
http://share.shutterfly.com/action/w...0BYtWrhw2csXLA
Old 07-29-2007, 04:56 PM
*shrugs* The time seems legit to me, every time I look at it and the race. Here's two of the comments from DRF.com's article that, to me, confirm it. (I think there's some sputtering about it being Lawyer Ron who did this performance and it's not really fair. If you go by what you might've thought him capable before his Derby flop, I could see him getting to this point one day. 128 might be crazy but no way is this a 107-110 performance either. His reputation was very what has he done for me lately and he's working his way back. He got a track record and it sure looked like he was turning in one with the way he ran. Sometimes your eyes aren't deceiving you when you look at the final time. Kinda refreshing and the horse should be recognized for that.)
Silver Charm says:
TVG ran a bit of a side-by-side comparison between this Whitney and the one by Left Bank seeming to reasonably confirm the time.
Actually a half in 47.37 for a race that appeared to be speed laden seems more out of whack than three-quarters in 1:10.28.
Once the investigation is completed there will be two groups of people with some explaining to do.
If the time is wrong then NYRA chairman Steve Duncker will need to explain to fans and a National Television audience why the Track Record they were told they had witnessed was bogus.
If the time is correct then the Track Superintendant needs to explain why he and his crew felt compelled to "goose the track" before the Big Race.
Posted by: Silver Charm | Jul 29, 2007 2:14:14 PM
Sal says:
I hand timed the Whitney twice and got the correct final time on each occasion.
I did the same thing in the Go For Wand and also got the correct final time.
In multiple clockings of each race, I came within 0.27 seconds of having every split correct. That tells me the fractional times are accurate as well.
To come away with 1:48 and change clockings, as Mr. Davidowitz did, I believe you have to start timing just after the gates open and before horses reach the finish line.
Basically, getting the final time plus run-up.
Posted by: Sal | Jul 29, 2007 2:25:09 PM
Old 07-30-2007, 03:30 AM
Indian Charlie's Avatar
i know the person who posted that on drf, and trust me, he's completely incompetent. i'm surprised he even knows how to turn a computer on, let alone use a stop watch.
Old 07-30-2007, 05:30 AM
packerbacker7964's Avatar
packerbacker7964 packerbacker7964 is offline
Hippodrome Bluebonnets
Yeah but the timer doesn't start as soon as the gate opens either. It depends on where they have the starting gate at compared to the first timer on the tracks rail. Great run by The Lawyer but to many other horses would've had to run their personal best on the same day also. Hard yes, impossiable no.
Old 07-30-2007, 07:19 AM
Left Bank's Avatar
Left Bank Left Bank is offline
Why can't you all just enjoy it and be happy for the horse and his connections?
Old 07-30-2007, 07:32 AM
2Hot4TV's Avatar
2Hot4TV 2Hot4TV is offline
Time is only important where you are in jail. Lawyer Ron's win was by daylite over a very good field, now if he can just stay a mile and 1/4.
Old 07-30-2007, 07:58 AM
Left Bank's Avatar
Amen!!
Old 07-30-2007, 11:10 AM
King Glorious's Avatar
King Glorious King Glorious is offline
This is something I've tried to explain to people on the other forum. For some of u, that's how u see it. And that's fine. But for a lot of us that are more analytical, is't not that simple. Not knocking the other forum because it has it's place but on here, there are more serious horse players. And serious horse players want to know more about what really happened and not just the end result. If u don't analyze and try to figure out what really happened, u miss way too much when it comes time to wager on the next race. Nobody here is doubting that Lawyer Ron ran a very good race and it's obvious that whether he actually ran 1:50 or 1:46, he was dominant over the rest of the field. That much is not in question. But as a gambler, if u don't look deeper than the surface, u are cheating yourself.
The real horses of the year (1986-2020)
Manila, Java Gold, Alysheba, Sunday Silence, Go for Wand, In Excess, Paseana, Kotashaan, Holy Bull, Cigar, Alphabet Soup, Formal Gold, Skip Away, Artax, Tiznow, Point Given, Azeri, Candy Ride, Smarty Jones, Ghostzapper, Invasor, Curlin, Zenyatta, Zenyatta, Goldikova, Havre de Grace, Wise Dan, Wise Dan, California Chrome, American Pharoah, Arrogate, Gun Runner, Accelerate, Maximum Security, Gamine
Old 07-30-2007, 02:39 PM
classhandicapper classhandicapper is offline
Pimlico
I think it more than likely that the track changed speeds between the Ginger Punch race and the Whitney. If someone was actually at the track, they might know if the maintenace crew added water or worked on the track prior to the Whitney like they often do before feature races.
Old 07-30-2007, 05:02 PM
Downthestretch55 Downthestretch55 is offline
Ditto that! The rest is blood clot, mon.
Old 07-30-2007, 09:56 PM
I made my figs for the day and reviewed them with a fine tooth comb. The number Beyer gave him (and the rest of the field) was an adjustment (a 116.) Here's what I got (my fig then the Beyer equivalent in parentheses) and a justification:
R1 101 (73): No recent fig on the winner, 2nd place (beaten 1l) Wood Winner had a 98 last out.
R2 105 (80): [2yo's, although this is par for 2YO MSW at SAR]
R3 Turf
R4 100 (72): Winner had a 97 last out, 2nd (beaten 1l) 98, and 3rd (1l) 96. Probably a point or two high, but longshot winning races are often bizarre.
R5 106 (82): Another longshot winner, moved up 10 lengths (I don't have much confidence in this figure but there were a lot of firsters in there so not much to work off of)
R6 107 (83): Winner had a 104 last out, 2nd 100 (off long layoff), 3rd 103.
R7 Turf
R8 The AGVandy: 116 (104): Winner had a 116 in the Carter (last fig I have). Very evenly matched group on my figs and they ran like it. All were in the 113-117 range
R9 The Go For Wand: 113 (93): Winner had a 108 and 109 last two, steadily improving
R10 The Whitney 132 (123): Winner 125 @ Mth, 2nd (5l) 122 @ CD, 6th (10l)122 @ Aqu, 7th (11l) 120 @ Aqu, 9th 122 (12l) @ Bel, 10th 119 (14l) @ Bel
R11 99 (70) Winner a 99 last out, 3rd (3l) 96
Basically the top 3 ran their eyeballs out. It happens. They probably won't run that fast again, ever. The Beyer just CANNOT only be 17 points higher than the Go For Wand- the time is 18 lengths faster, which at a mile and an eighth translates to 30 Beyer points (precisely what my figures state, even using a different method and scale.)
Take it for what it's worth but if the Whitney Beyer is "officially" a 116, the Go For Wand should "officially" be an 86. Neither are right as they stand.
Old 07-31-2007, 12:28 AM
sumitas sumitas is offline
If the NYRA cannot verify the clocking then they should throw the time out and leave the track record as it was. In other words Lawyer Ron should be awarded the unofficial track record. The official track record stands.
