Old 06-12-2007, 10:16 AM
jpops757 jpops757 is offline
Sheepshead Bay
Default looking back
The Belmont unfolded about as formfull as could be expected. We saw a wonderful race with a deserving winner.One thing that bothers me is some of the experts are saying the 5 lbs had no effect on the outcome. A 12 F race that ends up as close as this one, the weight coulda made a differance.Maybee not but for anyone to say it was not significant , I question there objectivity. Kudos to both and thanks for a race to be remembered.
Old 06-12-2007, 10:23 AM
sure, weight could have made a difference. But I think Rags to Riches stumble at the start and 4-5 wide trip the whole race it more than made of the difference of the weight.
Old 06-12-2007, 10:30 AM
ddthetide's Avatar
Rags covered ALOT more distance than any of the top 4 finishers.
Coach Paul Bryant
Old 06-12-2007, 10:38 AM
slotdirt's Avatar
slotdirt slotdirt is offline
Hard Spun ran about 7f before they even made the first turn.
Old 06-12-2007, 10:42 AM
If you're into sheet figures...and believe in that sort of thing....I believe 5lbs at the distance of 1 1/2 miles equals 2.5 lengths.
Old 06-12-2007, 10:46 AM
ddthetide's Avatar
does belmont do the distance tracker like keeneland? i'd be interested to see the differences in trips.
Coach Paul Bryant
Old 06-12-2007, 10:53 AM
Sheepshead Bay
I agree with all of you. The race is run with the pace and conditions and we had a very deserving winner. I think a lot of things influnce the results and the 5 lbs is one of them. I am not saying Curlin had an excuse for the loss,but if the weight was not a factor why do the allow it?
Old 06-12-2007, 10:55 AM
FWIW
I went to there site and looked it up....according to their calculations...at 12 furlongs, five pounds equals exactly 2.40 lengths.
That gets adjusted into their figures....as does their belief that one path of ground on the turn equals one length.
Old 06-12-2007, 10:57 AM
The wide trips dont matter when you run the leader runs the first 6f in 1:15.37 and the mile in 1:40... the stumble was negated by the incredibly slow pace. It allowed her to settle and be perfectly comfortable. A stumle like that in the Derby would have been lights out, and we may never have seen this filly run against the males again.
Old 06-12-2007, 11:01 AM
ddthetide's Avatar
FWIW
that equals out pretty well then. Rags was 4-5 wide the whole trip and Curlin was 2-3?
Coach Paul Bryant
Old 06-12-2007, 11:04 AM
I agree that trouble is never more overrated than when it happens during the slowest part of the race....and also that racing wide while the pace is so slow is no disadvantage at all...as you're in the clear and really giving nothing away. And Belmont is just about as forgiving a track as any to be wide on.
In the Belmont, the meaningfull ground loss would be on the final turn...when the real running was finally starting.
Ground loss is most severe in real fast-paced two-turn races, with a short run into the first turn. If a horse gets hung wide while gunning for the lead in that situations...he's a very likely candidate to tire markedly later on in the race, as those type of horses often run well below form.
Old 06-12-2007, 11:29 AM
MISTERGEE MISTERGEE is offline
to me the complication of figuring ground loss comes when the better spot on the track is the outside not the inside. then it is an advantage to be out there not a disadvantage. also how often these days do you see a horse coming down the rail form off the pace and drawing away? it seems those days are over. most winning moves are made coming around horses.
Old 06-12-2007, 11:46 AM
The Kentucky Derby was a very recent famous example of that....although I guess you can say Street Sense wasn't "drawing away" from pacesetter Hard Spun late...but a certain habit of his had a lot to do with that I would think.
Old 06-12-2007, 12:39 PM
I have no idea why you would think this? Ground loss is ground loss regardless of pace. Running further than your rivals is a disadvantage period. The stumbling instance may be negated by a slower pace because she did not have to work hard to catch up. But simple physics says that 4 wide is 4 wide no matter the speed you are doing it at.
Old 06-12-2007, 12:41 PM
Ground loss is ground loss is ground loss. If they were running on a track with a severe dead rail then it is not as big of deal because there is an X factor that is slowing the inside paths down that negates the ground loss.
A perfect example of this is just about any 2 turn long grass race. Usually the pace for longer grass races is moderate and saving ground is of the utmost of importance in these races.
Old 06-12-2007, 12:46 PM
Physics may say that...however, ground loss is most certainly more significant in some situations than others.
Let's say you have a 12 horse field, with a very short run to the first turn. If a horse gets hung up four-to-five wide, while up on a fast early pace....that horse is almost certainly going to ran FAR below his best form.
I've seen horses breaking from those very difficult posts, in much slower paced races, get hung up through the first turn...and still run to their best form.
I know a lot of other very capable trip handicappers (BTW would agree with me on this) feel the same. When the pace is very slow, I actually don't mind it that much if the runner I bet is caught out in the clear.
Old 06-12-2007, 01:01 PM
ArlJim78 ArlJim78 is offline
Newmarket
Adding a hot pace and a wide post are two other important variables that effect the outcome. But like Cannon said the ground loss is the same. Its just that in the scenario you've described those other factors exacerbate the effect on the overall performance.
Old 06-12-2007, 01:02 PM
explain grass racing
Old 06-12-2007, 01:04 PM
I obviously agree with your point in an earlier posts about biases.
As for grass races...I still think in those turf races, the faster the pace is early, the more ground you want to save through the first turn. Fast paced turf races are often won by horses who make "inside-out" moves. Having a fairly good tactical spot while saving some ground around the first turn, and swooping around the tiring horses who are backing up inside of them.
John Velazquez has always had dazzling ROI stats in turf races throughout his career...and he rarely makes a great effort to save ground in most turf races...he's the one rider I'd actually prefer (off of stats) in a slow paced turf races. Ramon Dominguez makes a great effort to save ground, and is very skilled at riding the inside...he's also always had great ROI numbers on turf...and would be my pick for best rider in fast paced turf races.
Old 06-12-2007, 01:13 PM
That's very true.
However, just from watching so many races for so long, If they are flying up front...and my horse is a closer I'd strongly prefer he'd be inside the other closer or closers, and hopefully would not be hindered by the tiring horses in front of him...and either get a dream run up the rail...or be able to get off the rail and get the kind of "inside-out" trip you like.
If the pace is slow--they are probably up against it no matter where they are placed...but I see horses positioned outside often run as good or better than horses positioned inside of them.
