Old 05-10-2007, 02:01 PM
somerfrost's Avatar
Default Did Hard Spun clip heels with Street Sense?
Something of interest...I though Street Sense cut over in front of Hard Spun very quickly in deep stretch but i didn't notice any significant reaction by Hard Spun nor of course did the jockey claim foul...nevertheless, an interesting post:
The Homestretch
> Triple Crown Racing
> The Zapruder Film Of The Derby?
archer
Registered User
(5/10/07 8:22 am)
On another thread Modax said of Hard Spun in the Derby:
"He took a couple of bad steps on the backside, and another after Street Sense veered in front of him." On another board someone posted the following.
Since I had nothing to do at work, I took a look at the video to determine once and for all if Hard Spun and Street Sense clipped.
I inverted the video to a black and white negative image and blew it up 6.5 times. I also slowed it down to frame by frame movement. I used the iso of Street Sense and the blimp camera. When this is done, the horses are white images imposed against the very dark track. The jockeys are black bodies riding the white horses. This allows for a much easier way to see the images of the entire horse. Also, the white wrap on the back leg of Street Sense becomes a black wrap on the white leg.
The kinetic motion of Street Sense's left rear leg is disrupted. The cause of the disruption is the left front leg of Hard Spun. Hard Spun, who at this point was striding out with the left front has his foot shift to the left. It caused his foot to plant improperly and lead to the stumble and his head dropping rather dramatically. Street Sense's left rear hoof clearly shifts to the right during the contact.
The blimp footage clearly shows the two white legs (Hard Spun's left front, Street Sense's left rear) blending as one. If Street Sense was clear when he moved over, the white images would have remained seperated by the dark dirt. This did not happen. Two strides after the eighth pole, the horses where making touching.
I am absolutely 100% certain the horses made contact. The video evidence of the iso cam showing the disruption in the kinetic movement of the horses is indisputable.
I also checked earlier in the race where Hard Spun seems to drop his head. The only times he seems to lower his head out of the ordinary is when he is changing leads. He did not change leads at the eighth pole.
Old 05-10-2007, 02:18 PM
It's a nonissue because it didn't affect the order of the race, but it appeared to me like it was very possible there was a minor amount of contact.
Old 05-10-2007, 02:20 PM
somerfrost's Avatar
Yeah, I don't see it as any issue, just something interesting. I thought as I watched the race that SS was guided to the rail quicker than necessary after passing Hard Spun, the kinda thing that could be a problem...but wasn't.
Old 05-10-2007, 02:27 PM
slotdirt's Avatar
slotdirt slotdirt is offline
There was a definite bobble by Hard Spun, but whether it was caused by wobbly legs or clipping heels is up for debate.
Old 05-10-2007, 02:29 PM
Saw the same thing, but when you look at the overhead there's room and no contact (see the NBC site for overhead views)
Old 05-10-2007, 02:34 PM
slotdirt's Avatar
Speaking of Hard Spun, how can you not love Larry Jones? I particularly like the quote where he says he told Borel if he goes to the left of Hard Spun, he's going to be running on the turf course.
http://tcm.bloodhorse.com/viewstory.asp?id=38874
Old 05-10-2007, 02:37 PM
somerfrost's Avatar
LOL! Just so he doesn't get caught up with that like Woody Stevens did with Winning Colors in the Preakness...that kind of stuff is bad for racing!
Old 05-10-2007, 02:39 PM
slotdirt's Avatar
Anybody have that overhead video saved somewhere? I am striking out on the NBC website.
Old 05-10-2007, 03:28 PM
moke0043's Avatar
moke0043 moke0043 is offline
Detroit Race Course
http://www.youtube.com/watch?v=OmzjCLKTSKc
Old 05-10-2007, 03:33 PM
somerfrost's Avatar
Originally Posted by moke0043
Can't really see on that vid...again, it wasn't a factor just something of interest!
Old 05-10-2007, 03:40 PM
tector's Avatar
tector tector is offline
Sheepshead Bay
What is the supposed conspiratorial reason for HS connections failing to even mention this (much less their failure to object)?
HS ran a great race, just a bit too fast early. The rest is crap.
Old 05-10-2007, 03:48 PM
somerfrost's Avatar
Can you read or do you just like to make accusations? I think I clearly stated from the beginning that this was a non-issue merely something of interest. It COULD have been a problem but wasn't. Obviously the jock would have raised the issue if it would have impacted HS...SS was clearly by and winning the race. Nobody is saying anything other than it is part of the race and something interesting...would HS have finished a bit closer? Was he bothered even slightly? These are things to consider moving on to the Preakness!
Old 05-10-2007, 03:59 PM
AeWingnut's Avatar
Mario Pino should have flopped like Dennis Rodman. I've had horses taken down with acting jobs
ΜΟΛΩΝ ΛΑΒΕ
Old 05-10-2007, 05:02 PM
MarkyD MarkyD is offline
Pimlico
Damm I lost 8K with HS getting beat, took a couple of days but I got over it. It seems like Jones just keeps emphasizing about that rail opening up. It's done, it suck I know, but he has to let it go.
Old 05-10-2007, 08:43 PM
easy goer
I thought we had settled this issue but it has reared its head over on the about website. A fellow there named depalma is responsible for the quote at the beginning of this thread.
He claims that you can see the clipping on the overhead, which I am very doubtful of. I'll have to look at it again.
It has been pointed out that HS runs like this but subsequently it was pointed out by others on about, that a) he did not run like that in the Lanes End and b) he did not bob his head like that on a regular basis in the derby only when changing leads. (depalma on the latter)
I clearly saw HS on the video bow his head before reaching the far turn. Right after the announcer calls out SEdgefield and Teuf. Whta I am not sure of is whether HS is doing this every so often on the backstretch. THought he was but the buildings get in the way. Depalma is sure he didnt do this and only does this when he changes leads.
So the mystery deepens.
THe comment by Tector I dont see as meant to be antagonistic but rather a question as to whether if this was really a clipping some objection would have been voiced. I.e. since the jock didnt object probably it didnt happen, i.e it is circumstantial evidence that it didnt happen. I think that's a fair pt. .
Old 05-10-2007, 08:58 PM
Damn, I lost 0.00K by HS getting beat....and I still can't get over about how the rail opened up for SS.
Jones might stop emphasizing it sooner or later....but, I would think it's something that will always be in his head for the rest of his life.
Old 05-10-2007, 09:55 PM
cal828 cal828 is offline
Look on the ESPN horseracing site. I think their video is the same as the NBC video. Shows the overhead just as the horses are rounding the turn into the stretch and Street Sense is making his big move.
Old 05-11-2007, 01:11 AM
tector's Avatar
Sheepshead Bay
Originally Posted by easy goer
The comment by Tector I dont see as meant to be antagonistic but rather a question as to whether if this was really a clipping some objection would have been voiced. I.e. since the jock didnt object probably it didnt happen, i.e it is circumstantial evidence that it didnt happen. I think that's a fair pt. .
My point was meant to question the logic of the author of the post originally posted elsewhere--if this incident, in fact, happened, logic would seem to dictate that SOMEBODY connected to HS would be complaining about it. I take their silence to be a tacit omission that it did not occur.
Peace be with you. Or, as Harvey used to say, may the horse be with you.
Old 05-11-2007, 03:56 AM
Pino didn't say a word about any contact Saturday night when discussing the trip. You'd think it would have come up had there indeed been even the slightest brush or clip...
Old 05-11-2007, 06:42 AM
The Bid's Avatar
The Bid The Bid is offline
Maybe horse got a little scared when SS came into his path, obviously he was tired, maybe he was a little sore. Who knows why he made that heavy switch, I dont think it was made by contact.
