Go Back   Derby Trail Forums > Main Forum > Contests
Old 03-07-2007, 08:46 PM
randallscott35's Avatar
Idlewild Airport
Default Place Vs. Fave/Long Exacta Running Tab
Alright here it is. (Mods-if you would, you can leave this in the Paddock for a day and then transfer it to the Contest Forum--thanks)
This will be based on a 250 Race sample starting 3/8/07 and running till enough races are run.
Any horse 10-1 or over finishing second(OR FIRST) will be given a place payout((read addendum at end of Paragraph) (obviously based on a 2$ base bet)---that will then be checked for the favorite of the race being on top...If they are, the 2$ exacta payout will go in the Exacta column. If they aren't it will still count as a race towards the 250. (ADDENDUM---as Andy rightfully stated I have short changed the Place side as if the longshot won the race you would get both the place and the win---that must be added as well)
The tracks used will all be large tracks with large pools that aren't skewed.
AQ---GP---SA until the contest is over. Somedays there will be a number of races that qualify and others I'm sure very few.
I will post after all the races are run for a given day and give a breakdown by track and then also the overall breakdown until its over. Anyone who wants to double check the numbers is of course welcome to. It will take a couple of weeks but it is worth it to have a larger sample spread against a few tracks.
So, let the games begin tomorrow...GRITS we can pm each other and figure out something to bet on this. Good luck.
