Old 09-11-2012, 10:39 AM
Default Random observations on 9/11
The effeminate morning guy on FoxNews said Building 7 collapsed due to a raging fire.
I might be a little slow but most buildings can sustain a fire.
Maybe we have a few engineers/scientists on the board that can explain to me how a fire could collapse that building.
Old 09-11-2012, 10:41 AM
CNN is talking about the iPhone 5 right now.
Remember....Never Forget.
Old 09-11-2012, 10:46 AM
You mean the building that could be seen standing over the shoulder of a CNN reporter as she told everyone it had already collapsed?? That building?
Old 09-11-2012, 10:53 AM
Yes that one.
I believe that's the same one that the BBC had a ticker running that said it collapsed while it was in the background of the live shot.
Old 09-11-2012, 10:55 AM
Herman Cain is sharing his experience at the golf course in Orlando, Florida during 9/11 on Fox News.
You know...working hard and whatnot.
Old 09-11-2012, 10:59 AM
CNBC talking about Steve Jobs.
Jobs said the U.S. lacks engineers.
What a coincidence!! Guess I'll be waiting for an answer to my question.
Old 09-11-2012, 11:00 AM
I don't watch the news on tv much, if at all.
I'm starting to see why things are so bad. If people are getting their news from these folks...whoa.
Old 09-11-2012, 11:16 AM
Jobs said the U.S. lacks engineers willing to work for slave wages.
ftfy.
How about the millions of engineers that lost their jobs due to outsourcing the last 10 years.. If it is said on TV then it is true right? Never think for a second those that those that are profiting from this behavior may also be the ones sponsoring the "unbiased" main stream media.
Old 09-11-2012, 11:41 AM
3kings's Avatar
3kings 3kings is offline
I laughed, but I can't answer your question.
Old 09-11-2012, 01:27 PM
http://www.popularmechanics.com/tech...ecture/4278874
and yes, rosie o'donnell you fat pig, steel does and can melt. but it'll lose it's integrity long before that happens.
http://www.popularmechanics.com/tech...eering/4213805
Steel melts at about 2,750 degrees Fahrenheit—but it loses strength at temperatures as low as 400 F. When temperatures break 1000 degrees F, steel loses nearly 50 percent of its strength. It is unknown what temperatures were reached inside WTC7, but fires in the building raged for seven hours before the collapse.
Old 09-11-2012, 01:32 PM
Clip-Clop Clip-Clop is offline
Random observation, Pres needs volunteers!
Oh yeah, something very sad happened 11 years ago too.
https://twitter.com/BarackObama
don't run out of ammo.
Old 09-11-2012, 01:38 PM
Apparently the failure of one column - of all of the columns in the structure - this one particular column - could have caused the type of controlled collapse with a relatively small debris field witnessed:
http://www.structuremag.org/Archives...sanz-Nov07.pdf
CNN and the BCC reporting it live before it happened? Well, they still don't have the answer for that one.
I'd like to see some statistical odds of that happening to building 7, RBE. Has to be real small.
Yes, zig. But even you agree that really doesn't answer what happened to building 7.
I've been accustomed to seeing fires in most building collapsing a corner of the structure. But I don't believe I've ever seen a building like 7 collapse the way it did from a fire.
Old 09-11-2012, 01:41 PM
did you read the whole report? seems part of the issue with 7 was the way it was engineeredd/built.
Old 09-11-2012, 01:46 PM
Because of the footprint and the type of structure that 7 was the only likely cause of the fall that would make some sense structurally that I could come up with (along with a few structural engineers in my office) is that the underground support structure was compromised by the collapse. Hence the straight down fall into itself. Lower Manhattan, particularly that area is basically suspended over tons of open space for the tubes. I had them actually write something up for me. I will see if I can find it.
Old 09-11-2012, 01:48 PM
That would be great. Thanks!
Old 09-11-2012, 01:59 PM
We no longer have it here, since our server died but they pointed me to the "widely known" (they are engineers mind you) Structure magazine article confirming their theory.
