Old 04-19-2007, 12:07 AM
easy goer
I understand the idea of the ideal distribution, but of course you are talking now of races run at different distances and possibly faster surfaces (e.g. the inner path on BC day) so it's real hard to compare.
Old 04-19-2007, 12:14 AM
Bobby Fischer's Avatar
Bobby Fischer Bobby Fischer is offline
Originally Posted by easy goer
This is really good stuff Bobby, thanks.
I am looking at Curlin numbers and it seems that his figs are the same as the leading pace contenders. Yes? Is that because he is so far out in front or something else? It is hard to get a read on the field that he is in if his figs are the same as the field.
Thanks,
With curlin He actually WAS the primary contender(s) for each of his races. I like to have 3 primary contenders, a few races like the Tampa Derby (AGS,Street Sense) only have 2, a few only have 1. This is rare and indicates that he far out-classed the fields.
Could be good or bad (hasn't beat anything? or undefeated derby favorite?). Also the case with Nobiz in the Remsen(where he ran some of his best numbers). Another oddity is the Fountain of Youth where Nobiz has the same pQ-velocity(6 furlong velocity) as the race pQfig because he was 1.5 lengths back which happened to be the average of Stormello, Scat Daddy, and Nobiz at 6 furlongs (4.5/3).
Stormello had the highest pQ-velocity for the FOY as he was 0 lengths back (leader at 6 furlongs).
Old 04-19-2007, 12:25 AM
Originally Posted by hi_im_god
because you're handle was so obscure?
you know you named yourself after a delusional anti-semite right? i only ask because i have always been so careful what other's might think of my name.
lol.
I like the name. I like the level the guy reached at his profession. Nothing whatsover to do with anti-semitism (or any other statements/beliefs the man has made).
I have no special interest in chess other than that it is a fine game.
Old 04-19-2007, 12:45 AM
a little bit of analysis of the figs:
Circular Quay has not in the last 4 races(possibly never) run a faster pQ2 than his 6 furlong pace velocity. IMO he would have(and also likely won) in the Breeders Futurity at Keeneland had he not been trapped on the turn. The Risen Star was also upset by the spill. IMO CQ would have needed to come on much more than he appeared likely before the incident to run a faster Risen Star pQ2.
Street Sense on the other hand has outrun his pQ TWICE, and maybe most importantly- also came close to doing so in the Tampa Derby.
This is interesting look at use of energy by two horses who are commonly lumped together as both being deep closers. Does it indicate a possible stamina/finishing edge for street sense? or did he simply have a great trip in the BC, and a polytrack finish in the Bluegrass? I think there is some (small?) positive edge to Street Sense here.
Old 04-19-2007, 10:11 AM
Thunder Gulch's Avatar
Thunder Gulch Thunder Gulch is offline
Guys, the first thing you need to do evaluating the Derby prep figures - and poly races in general- is get out a big fat black sharpie and draw a line through them. Then you can move on and make some relevant observations.
Do I think Charity can win? Well, I am walking around in yesterday's suit.
Old 04-19-2007, 05:26 PM
easy goer
This is kind of a clumsy sentence. Are you saying; "Even w/o the spill, CQ was not likely win the Risen star?"
I would tend to differ how far back from notional was he,4-5 lenghts? His final time was messed up but wasnt that because of the spill? I know his final quarter time was not good but look at the final 1/8.
Old 04-19-2007, 10:14 PM
Agreed.
I think Circular Quay may well have won the Risen Star without the spill.
Beyond winning-
Comparing the pQ and pQ2 figures
Circular Quay would have really had to catch fire and win by open lengths in order for his Risen Star pQ2 velocity to have been faster than his Risen Star pQ1 velocity.
Circular Quay has not had pQ2 > pQ1 in his last 4 races (likely never).
Street Sense has done it twice in the last four.
Old 04-19-2007, 10:36 PM
Big problem I have is how the distance covered is measured. That has to be accurate or this is a mess. Does one go out there with a unicycle measuring device and follow the path of the horses?
This one reason I have never trusted speed measured this way. Another thing is the wide trip v. the rail. Depends a whole lot of the curvature of the turn. Some horses run well with that right side taking over and some horses run better in a stretch where one side does not have to dominate the other. Also horses that are lugging out or in may cover a lot of ground in a good time but they also might be dead tired compared to a horse who is full of run in a straight line path, running evenly and efficiently... in the figures this would work out to be slow because it was straight(again assuming distance is measured accurately)
Also horses that have changed speeds a number of times might have a low average time, but actually may have run a much tougher race because of having to change speeds (a bit hesitant to move thru a hole that closed, etc...)
Figures and numbers can be helpful (more so in betting, not as much in assessing a particular run) I will stick with my eyeballs and some basic figures in assessing a race. Nonetheless, it gives one something to ponder.
Ok I see Trackus... how is measuring distance accurately done by trackus?
Old 04-20-2007, 12:08 AM
The Trakus uses a microchip in the saddle bag to chart actual ground covered.
There are actually two different distances to consider here. Trackus measures actual total distance run by the horse.
If the horse raced wide and changed paths he will have covered more ground. (Street Sense actually had the highest ft/s velocity in the Bluegrass).
With Linear Distance, path is not considered. It is simply how fast a horse ran to each point of call and finish using 660 feet per furlong.
To calculate linear velocity I currently use 8feet per length(spacing of safety rail posts) for beaten lengths at point of calls and a seconds/length conversion at the finish line as the photo finish companies do.
These figs were originally designed to be a nice tool for showing a more accurate race shape. The human eye and judgement is where it's at. Everyone who sells figures tends to hint that they pick winners - I would be happy if I narrow my search a little, have a frame of reference, and maybe have something to look for on the replay.
Old 04-20-2007, 12:20 AM
I did not read closely enough. I thought most of these numbers were based on total distance run. I thought that was the crux of the whole idea... anyways:
How did a company get to put this kind of technology in the saddle? At any track? Through NTRA or what...? I know its not like extra weight, I would just like to know how they got the rights to gather this sort of data and distribute it?
Old 04-20-2007, 12:28 AM
Right now, I know of Trakus at Keeneland and Woodbine only. They offer the Trakus as a service, and one of the main uses is to show the position of horses during the simulcast of the race. Information is available at Keeneland's website.
Old 04-20-2007, 02:21 AM
easy goer
Agreed.
Beyond winning-
I would not put great stock in this, (not sure if you are). SS's last race on the polytrack well surely any horse could have produced a better final speed than early speed. Given the way it was run. That doesnt say much.
As to the other race, I'm guessing it was the TB derby, they came home w/ a strong tail wind so that probably explains it.
Like I said, I dont know if you put much stock in this but you've obviously formulated your ratings in order to reflect something like this. It matters to your way of thinking. Could you elaborate then on why you think its important to compare these pQ1 and pQ2s to one another. What do you think is going on?
ALso, left off from last time,where do you come out on Great Hunter do you think he was tiring? thanks
Old 04-20-2007, 08:45 AM
It isn't a formulation of a rating, it's simple physics (average velocity = distance covered/time)
The value of comparing a horse's average velocity in the first half of the race to the second gives you a quantitative value on how much they slowed down in the second half of the race (99% of dirt races are run faster in the first half than the second.) Those that slow down less are more apt to stretch out.
Old 04-20-2007, 11:19 AM
Exactly.
In simple terms it tells you how much a horse slowed down.
In the Bluegrass several horses actually "came home" the last 3 furlongs faster than they started. That race started very slow and was run on polytrack. In the Breeders Cup Juvenile only one horse- Street Sense, ran a faster pQ2.
These types of comparisons have to be viewed in the context of the race, and may or may not show any worthwhile information.
I will post more Kentucky Derby contenders (Great Hunter, Tiago, Dominican, Any Given Saturday likely next - Also open to posting any Derby Horse that someone may request),
and I will also eventually post a complete list that shows all the figures as well as some extra comparisons and manipulations of the data along side.
Old 04-24-2007, 12:28 AM
Great Hunter
more Contenders to come...
Also have been working with some formulas to rank performance and also to rank stamina. Will be included in some final reports along with the horses rated in various categories.
Old 04-24-2007, 12:51 AM
NoCarolinaTony's Avatar
NoCarolinaTony NoCarolinaTony is offline
Suffolk Downs
[quote=Bobby Fischer]
(click and open full screen)
Here are my figures for Street Sense's last four races. Also included here is an in-depth look at the Bluegrass Stakes using Trakus Data with my figures.
Pace Quality or pQ attempts to measure the pace of the primary contenders in a race at the pace call. This can be important in identifying a true race shape. pQ2 measures the pace of the primary contenders from the pace call to the the finish. The Bluegrass was a visually obvious example of a race that "came home fast". Figures are listed in feet/second velocity.
Are you sure your figures are accurate. I was at KEE and Dominican was behind Street Sense at the pace call and up until he nosed hom out at the wire. There is no way SS is faster closing than Dominican.
Thanks,
NC Tony
"Now back to you Win Elliott" FC
Old 04-24-2007, 01:11 AM
Thanks,
NC Tony
NC
You are correct.
Here is better update with everthing rounded to 2 decimal places. Look under "PaceCall to Finish". Dominican closed the last 3 furlongs at 58.72 feet/second, while Street Sense was at 58.35.
also here is Dominican's card
DOMINICAN
Old 04-24-2007, 10:25 PM
HARD SPUN
TIAGO
Old 04-24-2007, 10:27 PM
GPK GPK is offline
5'8".. but all man!
HARD SPUN
TIAGO
huh??
Old 04-24-2007, 11:42 PM
Originally Posted by GPK
huh??
These are some of my velocity figures for the Derby entrants.
The numbers are in feet per second. 3 main parts = pace call (6f route or 4f sprint), pace call to finish (how fast they came home) , and final time.
