Go Back   Derby Trail Forums > The Charles Hatton Reading Room
Old 10-09-2014, 10:27 AM
Originally Posted by freddymo View Post
Agreed with most of this. Should we take away ulcer meds like gastroguard or Nsaid's for inflammation? I am sure horses are faster when treated with theses as well.
I would still need Nexium daily if I was a world class tennis player and I would play worse if I was suffering from GERD while trying to beat my opponent. If I twisted my ankle and took an Nsaid for inflammation it would be easier for me to play without as much pain and I would likely play better. I like you know Lasix makes horses run faster then if they don't take it but I am not sure if the playing field is level, and it isn't masking other nefarious drugs, why that is necessarily a bad thing.
I like you dont get why you give a horse lasix if it is not indicated unless its use is so important to prevent bleeding.
I figure in 2 years its out of the game race day anyways
I don't think those other things make a horse that doesn't need it run faster if administered. I'm sure Lasix does. If Lasix is needed, fine, but it has gotten out of hand. And those that get it should be penalized. Weight is one idea, and seems a pretty good one to me.
@TimeformUSfigs
Old 10-09-2014, 10:38 AM
freddymo freddymo is offline
Since vets dont believe Lasix makes them run faster I am sure they will agree with your premise.
Old 10-09-2014, 10:40 AM
What are you trying to say? Makes no sense, but...
I think Jerry Brown, and even myself, know more about measuring horse speed than vets do.
@TimeformUSfigs
Old 10-09-2014, 10:44 AM
Danzig's Avatar
The point is pretty simple for me. Horses that use Lasix have a speed advantage over those that don't. I'm not a scientist, I don't know the exact reasons why. I really don't care. I just know it is so. That is how we got where we are today, where horses that don't need Lasix are given it all the time.
We are told now it is preventative. But, that isn't the main reason nearly every horse is given it. It is given to level the playing field. Jerry's idea tries to level the playing field without giving drugs to 95% of the horse population. I think it is a good idea. How can less drugs not be good?
when reading the report on the study, they said that a horse doesn't improve due to lasix, but they are able to run to their level because they don't have the bleeding issue. did you read the study? did you see the percentage of horses affected by bleeding?
if people don't wish to use it on their horses, they don't have to. but it is helpful to many horses, and should be allowed.
lasix doesn't make a horse 'run faster'.
horses may not bleed for some time, and then suddenly they do. that's why people use lasix, they have no way of knowing when it'll happen to a horse.
read the study, seriously.
Old 10-09-2014, 10:55 AM
I am saying that vet's dont think Lasix makes horses run faster and as such they will agree with your premise that Nsaid's and Ulcer meds dont either.
Old 10-09-2014, 11:01 AM
I've read it, I just disagree. There are studies out there showing just the opposite that have been posted here before. I've been doing this a long time. I know how to measure horse speed, and I know that horses run faster with it than without.
There is ample evidence if people bother to look. As a bettor, I can quantify it. Horses that don't bleed run faster with Lasix than without. It isn't even really debatable. Of course horses are individuals and the effect isn't the same on all of them, and a scant few run worse. But by and large, it improves performance.
As for the preventative aspect, wasn't a study just released that purported to prove only a very few really need Lasix long term, and that bleeding doesn't hinder long term performance?
http://www.bloodhorse.com/horse-raci...six-not-needed
I take them all with a grain of salt because everyone has an agenda. My agenda is to make money betting. It may be selfish, but it isn't slanted to one cause or the other. I look at it objectively.
Here is an example that won't happen because I think Goldencents is going in the BC Mile. If he met Rich Tapestry again, after his trip last time, I'd bet him in a second over Rich Tapestry. But, if Rich Tapestry were to add Lasix, I'd bet him. I've been doing this long enough to know Lasix makes a difference, and the difference is not heads or noses but lengths.
@TimeformUSfigs
Old 10-09-2014, 06:30 PM
Danzig's Avatar
but unlike other studies, this was actually done under racing conditions. now, it wasn't done to detect whether it made horses faster, but it most definitely showed that it helps regarding EIPH-which is the reason for its use. unless and until a better anti-bleeder comes along, I don't see a reason to stop using it. many horses bleed, the bleeding is lessened by using Lasix. are horses improved due to lessening instances and severity of bleeding? i would think that it was what you're seeing when you say it makes them faster. they are running without hindrance. and seeing in the report how often horses suffer from it, I'd hate to see it taken away because of a perception or belief that it is a performance enhancer. removing the hindrance of bleeding isn't an enhancer-it allows the horse to race at optimal levels.
Old 10-09-2014, 07:12 PM
I believe it helps, but I also believe it gives an edge. If a drug is allowed that helps some horses run faster, but others can't have it, how is that fair? We see where this has led...they all get it now. That is not good.
@TimeformUSfigs
Old 10-09-2014, 08:30 PM
GenuineRisk's Avatar
I have to say, two years ago I was in the anti-Lasix contingent, but I was persuaded by reading this board to change my position (it was actually Riot, and her accounts of other methods used in pre-Lasix days that convinced me. I thought Lasix was cruel because of the dehydrating effect, when, in fact, that's what actually helps protect the lungs). I think people miss the point of Lasix, which is that it's not a therapeutic drug; it's a preventative drug. It's meant to reduce the chances of a horse having an EIPH episode. Since there's no way to tell if a horse is going to bleed, better to administer it in case.
To me, Lasix is to racehorses as vaccines are to people. It's not perfect, it doesn't work in 100 percent of recipients, but it's the best option we have. And no, not every horse is going to have an EIPH episode, just as not every unvaccinated person is going to get chicken pox. And the majority of diseases we vaccinate kids against aren't usually fatal. But they can be, just as EIPH can be, and why take the risk of a horse dropping dead from EIPH in the middle of a race when there's a cheap and easy way of reducing the chance that will happen? We can't let the perfect be the enemy of the good.
I think we also dance around the issue that when we race horses, we are pushing them past what they evolved to do. And that's the point of athletics- challenging the body to its physical limit. But we get weird about it when it's animals- we fret about consent, and start to ask if what we do is cruelty (never mind that it's just about impossible to get a 1000 pound animal to do something it doesn't want to do). And that's the really hard part of the argument- if you say that really, most horses in hard athletic work are going to bleed in the lungs, even if only slightly, then the question we have to ask is, is it right to be racing them at all?
Of course, I think it's fine to train animals in athletic endeavors, but I think we have a responsibility to do the best we can to protect their bodies against the inevitable damage athletic careers will do. And I also think it's okay for trainers to make the decision not to use Lasix, if they feel it's in the best interests of their horse's health (like when Larry Jones felt Havre de Grace was having a bad reaction to it. Perfect, good, enemies and all that).
Old 10-09-2014, 09:04 PM
Danzig's Avatar
Except they don't all get it...and if they did, there would be no advantage. Knowing eiph can hit any horse, anytime, with no warning, and as the study said, it can kill...I think I'd rather have something to help bleeders, especially knowing its all there is for bleeders.
Old 10-09-2014, 09:05 PM
Danzig's Avatar
I have to say, two years ago I was in the anti-Lasix contingent, but I was persuaded by reading this board to change my position (it was actually Riot, and her accounts of other methods used in pre-Lasix days that convinced me. I thought Lasix was cruel because of the dehydrating effect, when, in fact, that's what actually helps protect the lungs). I think people miss the point of Lasix, which is that it's not a therapeutic drug; it's a preventative drug. It's meant to reduce the changes of a horse having an EIPH episode. Since there's no way to tell if a horse is going to bleed, better to administer it in case.
Old 10-09-2014, 09:22 PM
95% get it. Those that don't usually have a reason. You didn't address my point. By giving a preventative drug to some horses that gives them an edge, you basically create an unfair playing field and force those that don't need it to use it. I'm sorry, I'll never be convinced that drugging horses that don't need it is a good thing.
As I said in this thread, I'm fine with bleeders using Lasix, just make sure they are penalized somewhat for doing so to level the playing field. Forget me, a guy as respected as Jerry Brown is saying that Lasix gives an edge. Does that carry no weight?
@TimeformUSfigs
Old 10-09-2014, 10:04 PM
Harness racing article but addresses the arguments as they pertain to thoroughbreds also:
http://www.harnesslink.com/News/Bann...r-horses-97434
Old 10-09-2014, 10:18 PM
pointman's Avatar
pointman pointman is offline
How does increasing the chance that horses will bleed in races negatively affecting their performance without warning create a fair playing field?
Old 10-10-2014, 07:33 AM
Danzig's Avatar
force those that don't need it to use it-did you see how many horses bleed? you have to give it as a preventive, as there's no way to know that a horse will bleed-and many do at some point. any anti-bleeder, and right now Lasix is the only one I know of, has to be given as a preventive as there's no way to know beforehand that a horse will bleed. and it can be no bleeding to a bad case, or even cause death.
you'd rather it not be given because you feel it gives an edge, knowing that not using it would cause bleeders to bleed worse, and could cause serious injury or death?
the study basically said it levels the playing field for bleeders, because by being given it, they can run TO their ability-not beyond it.
I'd like to see a similar study done under racing conditions that would show me that it improves a non-bleeder. and then there's the issue of a non-bleeder becoming one. I'd rather prevent an episode than chance it-I'm not the one taking the risk, the horse is.
since you believe it does give an edge, I'm sure you bet accordingly. that's why the info is given, so you know.
from the study:
Results—Horses were substantially more likely to develop EIPH (severity score ≥ 1; odds
ratio, 3.3 to 4.4) or moderate to severe EIPH (severity score ≥ 2; odds ratio, 6.9 to 11.0)
following administration of saline solution than following administration of furosemide.
At least 80% of racehorses can be
expected to develop the condition at some time during
their career,1,2 approximately 60% of sudden deaths
during racing have been attributed to pulmonary hemorrhage
2 severe EIPH has been shown to adversely affect
race performance,3 and EIPH is believed to adversely
affect the overall health of racehorses.
so, we should tell those 80% of horses 'too bad'? can't use it on you because it might give another horse an edge?
Old 10-10-2014, 11:48 AM
Danzig's Avatar
http://www.nytha.com/pdf/the_lasix_question.pdf
• Much has been made of the effects of weight
loss on an athlete’s performance. The weight loss
effect of Lasix is
comparable to the weight
loss a horse might
experience if denied hay
and water for 24 to 48
hours before a race, as was often the practice before the advent of Lasix.
While Lasix use is strictly controlled, there is no oversight for if or when a
trainer takes away a horse's nutrients. Will this necessitate the
introduction of security to ensure that all trainers observe the same
protocol? Will it lead to headlines proclaiming, “Horses Starved and
Dehydrated Before They Race”?
• Lasix does not allow a horse to perform beyond
its peak natural ability. It alleviates, but does not
eliminate, a condition that hampers peak
performance. Anecdotally, historically and
scientifically, it has been demonstrated clearly
that EIPH adversely affects performance. Horses run slower when they bleed. Anecdotally,
historically and scientifically, it has been demonstrated clearly that Lasix is significantly effective
in minimizing EIPH. The refusal to connect these dots is the height of, “Don’t confuse us with the
facts.”
6) Does Lasix mask other medications?
• During the International Summit on Race Day Medication, EIPH and the Racehorse,
Dr. Richard Sams, PhD, director of HFL Sport
Science Inc. in Lexington, stated that, after the
American Association of Equine Practitioners
came up with a universally accepted standard of
practice for Lasix in 1983--recommending that it
be administered intravenously and at a time four
hours prior to a race--the concern that Lasix
could affect the detectability of other
medications was addressed. “That concern is
largely eliminated when [Lasix] is administered in
a tightly controlled environment, as it is in the
United States,” Dr. Sams said. He concluded, “I
don’t refer to [Lasix] as a masking agent. It’s
impact on post-race testing is not very
significant.”
17
• In an article in Daily Racing Form, Steven Crist said, “The whole issue of whether Lasix can
mask other drugs was a valid concern a generation ago--perhaps the best reason to oppose its
use--but from all veterinary accounts this is now a non-issue. The vastly increased precision of
testing, and a greater reliance on plasma rather than urine tests, has made this a moot point.”
Old 10-10-2014, 11:49 AM
Danzig's Avatar
2) They race without Lasix in Europe, in Hong Kong, in Japan. Why do we need it in the U.S.?
• Outside of the United States, the majority of racing jurisdictions still use archaic medical
science when it comes to an official diagnosis of EIPH.6 If a horse does not show evidence of
epistaxis (bleeding from one or both nostrils), they are not considered bleeders. With the modern
technology available to aid in diagnosis, this is the medical equivalent of refusing to use an X-ray
machine to diagnose fractures. It is irresponsible to wait for a horse to be in crisis to make a
diagnosis.
• Outside the United States, the majority of racing jurisdictions fail to officially acknowledge the
prevalence of EIPH, despite the incontrovertible
evidence that it affects the majority of horses.
BUT, trainers in Europe and Australia use Lasix
during training on a regular basis. The trainers
acknowledge its effectiveness in treating EIPH--
the ONLY motivation for using Lasix during
morning workouts is the alleviation of EIPH.
Old 10-11-2014, 10:43 AM
King Glorious's Avatar
King Glorious King Glorious is offline
Except cmorioles hasn't said that he'd rather see it not given. Not from what I've been reading anyway. He said he would just rather there be a penalty given to those that use it. The horse that just came to my mind is Smarty Jones. If memory serves me right, John Servis did exactly as cmorioles is talking about here. He felt forced to take it to make sure his horse was competing on an even playing field even though his horse wasn't a bleeder. If there was a weight penalty in place instead, perhaps Servis doesn't add the drug because the penalty would have the effect of leveling the playing field.
The real horses of the year (1986-2020)
Manila, Java Gold, Alysheba, Sunday Silence, Go for Wand, In Excess, Paseana, Kotashaan, Holy Bull, Cigar, Alphabet Soup, Formal Gold, Skip Away, Artax, Tiznow, Point Given, Azeri, Candy Ride, Smarty Jones, Ghostzapper, Invasor, Curlin, Zenyatta, Zenyatta, Goldikova, Havre de Grace, Wise Dan, Wise Dan, California Chrome, American Pharoah, Arrogate, Gun Runner, Accelerate, Maximum Security, Gamine
Old 10-11-2014, 10:44 AM
I just don't see how drugging nearly every horse to compete is acceptable. If that is what is needed to run the sport, then the sport will definitely go away at some point.
@TimeformUSfigs
Old 10-11-2014, 10:49 AM
Then we need to find something better than Lasix. It isn't all that effective anyway. There has to be a better way. But racing is never forward thinking in any aspect of the sport, and that includes medicine. Of course I'm not including illegal drugs where some are very forward thinking.
I don't buy the preventative argument. I've been around this game a long time. Never once was this mentioned when Lasix was being legalized. It was going to be a savior drug that helped known bleeders compete more often. The EXACT opposite has happened.
Like I said, I can live with Lasix for known bleeders, but they should be penalized. It clearly gives an edge. If you don't believe me, ask Jerry Brown. Like I just said in another post, in this day and age, if you have to drug nearly every horse so they can compete, the sport won't be around long. I'd bet anything on that.
@TimeformUSfigs
Copyright ©2000 - 2024, Jelsoft Enterprises Ltd.
