Old 04-20-2008, 11:06 PM
Mortimer's Avatar
Mortimer Mortimer is offline
Thistley Downs
Originally Posted by pgardn
Personally I am into capacitors.
And you know of Kirchoff.
So either you looked it up quickly
or someone has taught you.
And you remember.
Thats more circuitry stuff.
We will be starting off the yunguns
on charges that dont move and create fields.
Static electricity.
Now the ones taking the AP test. They will
be doing RC circuits.
How do you remember this stuff Morton?
Try fucl<ing with the high voltage cabinet of a radar set and you may really understand the art of learning on the run.
Of course..no one taught you this stuff..you were born with the gift of the shaman.
Cathode follower.
Old 04-20-2008, 11:19 PM
Cathode follower.
All I did when I was in middle and high school
was attempt to blow stuff up and set things on
fire. And it did not work well. So I read up on stuff.
And then things started working.
So I have sent some minor amperage through muscle
tissue. Knocked myself off a ladder and such putting
up a ceiling fan. Its important to shut down the proper
breakers when dealing with stuff in the house.
On the other hand we did make a rather large Tesla
Coil and it actually works. Its basically useless except
for throwing off big blue sparks and messing up radio
stations.
Morton I shall keep you informed on how it goes tomorrow.
And when I put the capacitors in the proper parallel arrangement
and get more charge going thru the primary coil I will inform you
how much bigger we get the sparks on the Tesla coil.
I can smell the Ozone now. Nighty night.
Old 04-21-2008, 07:27 AM
pee garden
of derby trail
is gay and ******
Old 04-21-2008, 08:22 AM
Mortimer's Avatar
Thistley Downs
Hossy...has someone gone off topic here?
I believe it's Coach Trou.
He must be punished.
Old 04-21-2008, 09:17 AM
*Sparkles in drill. 48 flat. Runs fifth in Michigan Derby*
Old 04-21-2008, 09:45 AM
Mortimer's Avatar
Thistley Downs
Next time...it won't go this easy.
Old 04-21-2008, 11:18 AM
*sparkles after 3 miles in 22 and change*
Old 04-21-2008, 11:19 AM
*plods home for 12th*
Old 04-21-2008, 11:25 AM
Mortimer's Avatar
Thistley Downs
^^^ No threat to tiring rivals passing him by.
Old 04-21-2008, 11:26 AM
^^^ Eased. Didn't take to the surface.
Old 04-21-2008, 11:29 AM
Mortimer's Avatar
Thistley Downs
^^^ Broke into dressage routine on backstretch....DQ'd.
Old 04-21-2008, 11:32 AM
^^^ Crossfired around the first turn. Vanned off.
Old 04-21-2008, 11:35 AM
Mortimer's Avatar
Thistley Downs
^^ Hung .....on first turn.
Old 04-21-2008, 11:37 AM
^^^Reared in gate, checked, did not cash.
Old 04-21-2008, 11:40 AM
Mortimer's Avatar
Thistley Downs
^^^ Gained ground in backstretch after falling down out of gate..........13 wide...showed heart in stretch....fell down again.
Old 04-21-2008, 11:45 AM
^^^Worked 47 and change with David Carroll in the saddle. Smoked a pack of Chesterfield's shortly after.
Old 04-21-2008, 11:48 AM
Mortimer's Avatar
Thistley Downs
^^^ Was in Dubai......poked out a 44 second 3 furlonger......then smoked a camel.
Old 04-21-2008, 11:55 AM
^^^Was in Australia. Led by 6 lengths at the half in the Greg Norman handicap. Caught. Pulled up. Choked. Vanned off.
Old 04-21-2008, 12:00 PM
Mortimer's Avatar
Thistley Downs
^^^ Eased in gate....DNF...and DNS......as well as FTDS.
Old 04-21-2008, 12:05 PM
^^^ Clipped heels, lost rider. Surfed the web. Drowned.
