Old 12-14-2016, 10:10 PM
hondo's Avatar
hondo hondo is offline
Louisiana Downs
If you use formulator then you don't want an android or an Apple tablet. Neither of those tablets can handle Flash (please go to HTML5!!!!!). If that's the case then you want to windows 10 tablet. On e point, I forgot could use the tablet version of formulator.
If you download your PP's from formulator first on your computer as a PDF then you could use either a windows, android or Apple tablet. however, I would get one as you indicated that was designed for a pen input. although the I[pad pro has a pen input the drawback is it can't handle Flash application.
Also want to have a screen it's really bright and the best for that are you that the iPads or the surface tablets. That way it allows you to view the tablet in a bright room or even in sunlight as long as it's not directly onto it. Only ones here are the surface and Ipads, they are the brightest with best contrast.
For the best writing experience you're either going to want to windows 10 tablet w/pen imput like a surface pro or the cheaper surface 3 Lenovo Thinkpad 10 or HP Sepctre tablet or an Apple pro tablet (no flash for regular formulator but can use the tablet version).
I have used both of surface 3 and an Apple iPad. The surface 3 is much easier to write on since it has was designed for pen input while on the iPad you have to use an aftermarket Pen it was not designed specifically for Pen but there are some good aftermarket pens out there that work fairly well. The surface 3 also can use regular formulator.
So your choice comes down if you're just viewing and maybe going to simply market pdf up a little bit and view formulator tablet you can go with an cheaper apple ipad or android tablet. However as I indicated if you want to view formulator and also have a better writing experience I get a windows 10 tablet unless you want to spring for the iPad Pro and use formulator tablet.
So I would recommend the surface 3 or a surface Pro M3 or I5 that you could get a good price is it Christmas time now. tablet unfortunately they're not gonna make it anymore so you have to get it on Amazon or somewhere on the Internet.As far is Wi-Fi or LTE you can actually get by on Wi-Fi. I have an Apple iPhone with a good data plan that I make into a hotspot and pull my Wi- did Fi right off my tablet if there's not available at the track. I do this instead of having us pay extra for an LTE connection just for the tablet.
If you need help just drop me a private message and I'll give you my cell phone number and go over it with you.
