Old 05-10-2012, 09:32 PM
No. You're bringing wind, pace, and trip into this and those are things that you know they don't account for.
If you took 5 competent figure makers -- and had them make a Beyer on a typical day when you have consistent weather conditions, accurate clockings, a race track that isn't being fooled around with a lot throughout the day, and a reasonable sampling of both sprint and route races to work with.
I would bet that virtually every single time -- all 5 figure makers would have every single horse to run that day on the card -- within no more than 2-to-3 points of each other.
True but you are making an awful lot of assumptions here. If everybody is using flawed info then of course they will all come up with a similar flawed number. I guess what I am saying is not that different figure makers will be 30 points off but that there is certainly a margin of error that is associated with every number assigned because things are occuring in a vaccum. So when you start comparing numbers of a single race a year apart I think that a few points could fall within the range of error. Especially in the case of the Derby which is such an outlier race. If horses were running 95 beyers as opposed to 109 I could accept the premise that they make. But 104 versus 106 versus 101 versus 108 all seems to hardly be conclusive
Old 05-10-2012, 09:35 PM
It can be argued that Beyer has "boosted" the figures of several Derby winners over the last several years. If anything, they should probably be lower than they are.
I will say I think it has more to do with the methodology than the horses. In any case, trying to use figures as a historical measure is always going to have problems.
Old 05-10-2012, 09:48 PM
IMO which is semi-educated though not nearly as proficent with numbers as guys like you and Doug, horses in general arent as good/fast as they were just 12 years ago when started training. Of course I have no actual data to back this up so I'm pretty much like the rest of the industry...lol
Old 05-10-2012, 09:51 PM
I'm not arguing one way or the other, just saying we don't really know. Any decline in figures is just as likely to be the result of figure making methodology as it is the horses, and the same goes for any increase in the figures.
Old 05-10-2012, 09:58 PM
You are probably right which makes the case I was making in my original post even more valid. That far too often opinions are used as facts and in the rare incidences when facts are used they are often misinterpreted.
Old 05-11-2012, 08:49 AM
The Bid's Avatar
The Bid The Bid is offline
no figure regardless of the maker will ever trump class as the most important handicapping tool. I could use any figure.. beyer, equibase, thoro, rag.. to me all of those are interchangeable. The class a horse carries is the benchmark for picking winners.
No figure is exact. They are all subjective and over rated as a tool to handicapping. I don't need Andy beyer or Len ragozin giving me their opinion when I'm gambling.
As for the significance of a slower beyer for today's horses... that's a laughable gauge of the breed
Old 05-11-2012, 09:53 AM
Port Conway Lane Port Conway Lane is offline
Raw final time has nothing to do with how fast a horse runs.
If it did -- $10,000 dirt claimers at Turf Paradise would be better horses than top Grade 1 males at Saratoga.
Raw final time is a laughably worthless indicator of anything because any race track can be made extremely fast or extremely slow, by any track super, on any given day.
A variant will find how fast or slow the track was VS par.
The brilliant Tizway won the 2011 Whitney over Flat Out in 1:52.43. Quality Road won the Woodward at Saratoga in 1:50.00 -- Curlin won it in 1:49.34 and Premium Tap won it 1:50.65 before running a close 3rd to Invasor and Bernardini in the BC Classic.
Tri Jet went 1:47 flat in the '74 Whitney going 9fs at Saratoga -- and he stumbled at the start and won with a last gasp lunge in a close finish.
If Groupie Doll didn't run Saturday would the beyer number for the derby have been higher?
Old 05-11-2012, 10:40 AM
It would have been the same.
Beyer typically splits his sprints and routes. Race #1 was a sealed track -- but the other 3 routes including the Derby all had the same variant.
Even if he didn't -- Groupie Doll is just one horse on a card with 10 dirt races -- she's not going to impact anything much by herself.
Old 05-20-2012, 09:57 AM
109 for winner and runner up. So the lack of steroids only deflates Derby figures?
Old 05-21-2012, 04:16 AM
pba1817 pba1817 is offline
Hawthorne
Excuse my ignorance, but I have a few questions.
1- How can "par" ever truly be "par" when we are dealing with living breathing animals? My point is in golf, we have a par, par is a static number, not taking into consideration weather or particular course conditions for that day, nor the performance of other "golfers" on said day. Maybe they all sucked that day,or maybe they were all excellent? Why should that have any effect upon a performance figure?
2- With the invention of racinos with their boosted purses on lower/mid level horses, does this not pull decent stock horses away from the major circuit tracks, and thus boosting their stock and "pars"? Subsequently lowering the stock and "pars" of the major circuit track?
3- It seems to me that quantifying figures off of "par" to relate to the sports elite level is backwards.
Old 05-23-2012, 10:40 PM
A follow-up article, Jeradi: The Science Behind Beyer Figures:
http://www.drf.com/news/jerardi-scie...-beyer-figures
Old 05-24-2012, 01:08 AM
Hawthorne
That article makes my questions even more prevalent than before. Jerardi writes early in the article that the numbers are exact math equations, then later in the article admits that the numbers are "about" or "around". It either it is subject to opinion or it isn't....
