Old 07-07-2008, 03:07 PM
Originally Posted by freddymo
salt water?
I like the thought.. maybe Epsom Salt water that may help take the sting out of the horses feet?
Old 07-07-2008, 03:08 PM
Would a knight lie?
A lie is not a lie if you believe it to be true...
Old 07-07-2008, 03:35 PM
parsixfarms parsixfarms is offline
I think lots of horseman would welcome poly/synthetic track instead of the Inner at the Big A.. The winter is rough and poly has to be easier to maintain. Having a track that is good shape to train and race on all winter isn't too bad an idea. So much money is spent opening and closing and harrowing tracks in the winter. it's a lot of work and it comes at a huge cost. Do you really love that inner biasis towards speed? Plus maybe they can have the main Aqueduct track open a tad bit earlier they already are racing on the turf two weeks before they used too with the advent of the plastic wrap
I always thought that, if NYRA was going to do a racing surface in synthetic, the Aqueduct main track would be the way to go. You could eliminate the inner dirt track (and create a wider turf course), and also allow for 7F and one-turn mile races during the winter, as opposed to the 6F or two-turn situation that we see with the inner.
If the potentially cold weather would be a problem at Aqueduct, why would it any less of a problem on the Belmont training track?
Old 07-07-2008, 03:53 PM
freddymo freddymo is offline
Although I am sure sir Simon is speaking from some past history and experience I am sure that Synthetics of some sort will work out fine once the right formula is worked out. I agree that might make some sense.. I have always thought the inner meet was a step child and I wouldn't screw with the main track but I guess you could.. Andy would know best what is on NYRA's mind... anyway they have no money so it is all BS for now
Old 07-07-2008, 03:58 PM
the_fat_man's Avatar
the_fat_man the_fat_man is offline
'TURFlike' racing in the dead of winter in NY. Where do I sign up?
Old 07-07-2008, 04:11 PM
I agree it is less then ideal.. Consider that horseman need a reliable track to condition their stock.. When the weather is really bad how can they do this? Plus NYRA losses a lot of dates when it's a rough winter so the alternative to Turflike racing is perhaps no racing at all. Most of the high powered barns and owners are following the sun so the only people who do suffer are the few that really can't afford to ship to warmer climates. Other then closing it down for 100 days a year it kind of makes some sense to mitigate the weather of winter and race on something synthetic.
Old 07-07-2008, 05:08 PM
There is a better shot of the fat Man sliming down and riding on the inner track as a 10 pound bug than there is of NYRA shutting down in the winter. The NY breeders would start jumping off the Throgs neck bridge in protest.
Old 07-07-2008, 06:43 PM
GenuineRisk's Avatar
And what of the windchill?
Wind chill is a figure meant to estimate heat being taken away from a living endothermic body; the wind doesn't actually change the air temperature.
That said, air temperature is usually measured a few feet above the ground, so the ground can be a couple of degrees colder than the air temperature.
We now return you to your regularly scheduled synthetic track discussion.
Old 07-07-2008, 07:08 PM
I think that Polytrack is considered a living endothermic body according to the Bid.
Old 07-07-2008, 07:14 PM
sumitas sumitas is offline
Couldn't they heat the aw tracks ? They heat football fields so they don't freeze.
Old 07-07-2008, 07:15 PM
Wink
The streak continues.
Old 07-07-2008, 07:30 PM
Wink
What about the fog ? Something has got to be done about dat !
http://www.youtube.com/watch?v=p1QQfpbCiw4
Old 07-07-2008, 09:50 PM
I think I see a plot for a horror movie here...
The Fog
The Blob
The Poly
Old 07-08-2008, 11:41 AM
Bobby Fischer's Avatar
Bobby Fischer Bobby Fischer is offline
Forget AW
Aqueduct inner should install my Pay Dirt™ SYSTEM .
A proprietary blend featuring Safety Soil™ (a unique system of banking at the rail for drainage)
we oughta cut a small-time deal to install carpet, i mean Pay Dirt, for a small short term profit for my buddies, in the name of safety.
